  • 1.  Ceramic sintering
    Posted 09-04-2020 08:55
    Ceramic sintering
    I have a sintering oven for ceramic using Nitrogen flow 8,000 liters / minute, the volume is 0.6 cubic meter. The pressure is 30 bar. My question is if to use battery of nitrogen gas or nitrogen generator?
    kfar saba il
  • 2.  RE: Ceramic sintering
    Best Answer
    Posted 09-07-2020 12:15
    The choice of the gas source is dependent on the amount of production/runs that you are planning to take and the economics. If you are going to run the furnace daily for 24 hours then a nitrogen generator may be suitable. For experimentation a bank of cylinders is much more convenient and flexible. Additionally consider availability of cylinders to your place of work and the lead time.
    I hope this helps.
    Vivek Singal
    Mumbai
    919769208775
  • 3.  RE: Ceramic sintering
    Posted 09-08-2020 14:12
    Thank you for your note.
    kfar saba il
  • 4.  RE: Ceramic sintering
    Pardon me, but those specs seem very high:
    That is changing the gas in the 0.6m^3 volume ~13x a minute!
    I am in the US, so 30 bar is 435psi.  You would go through a
    typical in a flash.  Our nitrogen cylinders typically hold 230ft^3
    or ~6.5m^3 at ~2500psi or ~170bar.
    Are you sure about those original specs?
    Jim Quinn
    Stony Brook University
  • 5.  RE: Ceramic sintering
    Posted 09-09-2020 06:42
    Thank You,
    I will check again the spec.
    kfar saba il
