We deal with a lot of compression molded PTFE, PPS and PEEK composites. Haven't used any iron or aluminum but bronze is very common to increase the thermal conductivity of the composite. Are you looking to get samples provided or needing help writing a robust material specification?
If your just looking for a assistance on a spec you should seek to define the following:
Blend / Composition
Grade / specs of each fillers
Mixing requirements
Compression molding requirements
Sintering requirements
Once you define the above you can mold some samples and conduct tests to define the material properties (mechanical, thermal, tribological etc.). Then change the above until you achieve the desired result.
Paul Watts
Director, Product Development Engineering
CECO Compressor Engineering Corp
Sent: 03-18-2021 10:39
Subject: Particulate reinforced polymer matrix composites
Dear connections,
I need a help and guidance to prepare "Non organic Particulate reinforced polymer matrix composites" especially PET as matrix material and iron or alumina or silica in powdered form as reinforcement material.
Request to guide on teh same. By a very raw method of compression molding it was possible to prepare samples for iron powder reinforced PET matrix composite. Results for compression, tension and flexural tests were encouranging.
Yogesh DANDEKAR
Assistant Professor
Cummins College of Engineeirng for women, Nagpur
Nagpur
09823016700
