Dear Eli.
I worked with Wayne Thomas, the inventor of FSW at TWI England, since 1997 on developibg tool materials for steel welding. Looking at the component you are intending to weld, I do not think FSW is the process to use for this application. There are several other techniques which have possibilities. What size are your components?
The material for FSW tools for welding steel are PCBN and these are very expensive, easily damaged and cannot be refurbished. Also your configuration appears unsuitable for this technique.
Best if you contact me privately on
david.rowe@cedarmetals.co.uk and we can discuss possibilities.
Best regards
David Rowe (ASM Member)
David Rowe
Company owner
Cedar Metals Limited
Billericay
Sent: 12-09-2020 08:58
Subject: FSW
@Rajiv Mishra, FASM - an expert in friction stir welding (FSW) may be able to assist. You might also reach out to the Edison Welding Institute in Columbus to address your FSW questions.
Hope that helps.
Sent: 12-09-2020 01:28
Subject: FSW
I like to get rid of TIG welding from the following detail, could you be able to suggest better solution ?
kfar saba il
Sent: 12-08-2020 14:00
Subject: FSW
@Eli Yudkevich can you expand on your question and we can see if someone has an answer or recommendation.
Sent: 11-10-2020 01:04
Subject: FSW
Hello,
Could somebody inform me about the FSW efficiency for carbon steels, for instant ST37 ? I have to weld 2000 parts per day..
Does it make sense to convert the welding line including 2 robots and 10 additional welders ? What are the quality issues if any ?
The parts are - Embrace pipe fittings.
Thank you
kfar saba il
