  • 1.  Spray cooling after Aluminum H.T ( 6061 )
    Posted 11-22-2021 01:17
    Hello
    I  am looking for consulting\help  by metallurgist or engineer experienced with design and construct of water spray cooling system( quenching ) following solution heat treatment of Aluminum. The specific parts are sheet metal made of 6061 alloy.
    Thank you
    kfar saba il
    IMAT 2022 - Registration Now Open
  • 2.  RE: Spray cooling after Aluminum H.T ( 6061 )
    Posted 12-09-2021 10:10
    I would suggest reaching out to @Scott Mackenzie, @George Totten, or @Kevin Anderson
    One of them might be able to help.
  • 3.  RE: Spray cooling after Aluminum H.T ( 6061 )
    HTS Board Member
    Posted 12-10-2021 08:06
    Hi Eli:
    Please advise how we can assist you......
    Thank you and regards,
    Chuck Faulkner
    Commercial Development Manager - Heat Treatment
    Quaker Houghton
    Conshohocken PA
