Martensite in Steel
  • 1.  Martensite in Steel
    Posted 03-08-2021 11:14
    Troy, MI
    248-840-1056
    Spring 2023 courses
  • 2.  RE: Martensite in Steel
    Posted 03-09-2021 01:10
    Hi Sanjay,
    Best regards!
    Joshua Jackson
    CEO
    US Corrosion Services LLC
    Spring 2023 courses
  • 3.  RE: Martensite in Steel
    Posted 03-09-2021 08:44
    Hi Joshua,
    Troy, MI
    248-840-1056
    Spring 2023 courses
  • 4.  RE: Martensite in Steel
    Posted 03-09-2021 08:54
    Usualyy, for as-quenced microstructure I use "untemperd martensite" or "tetragonal martensite".
    Andrea Talamini Minotto
    Villorba Treviso
    Spring 2023 courses
  • 5.  RE: Martensite in Steel
    Posted 03-10-2021 10:00
    Thanks Andrea. I should  designate un-tempered martensite instead of martensite. Clarifies my confusion.
    Troy, MI
    248-840-1056
    Spring 2023 courses
  • 6.  RE: Martensite in Steel
    Posted 03-09-2021 09:27
    Untempered martensite should be the right term in your report to distinguish it from tempered martensitic structure. This will provide clarity in your report, particularly for readers who may not have strong Materials/Metallurgical background.
    Nnaemeka
    Nnaemeka Ugodilinwa
    Process Engineer
    StandardAero
    Winnipeg MB
    2043187632
    Spring 2023 courses
  • 7.  RE: Martensite in Steel
    Posted 03-10-2021 09:43
    I would concur if you have untempered martensite to report it as such.  In the power industries use of CrMo steels and in particular martensitic steels like Grade 91 (Creep Strength Enhanced Ferritic Steel), we find untempered martensite in welds which were not given (or given an incorrect) post-weld heat-treatment and in components which were improperly heat-treated.  We would generally use a combination of hardness, optical metallography, and SEM-EBSD to confirm untempered martensite.
    John Shingledecker
    Charlotte NC
    (865) 201-1252
