Martensite in Steel
  • 1.  Martensite in Steel
    Posted 03-08-2021 11:14
    Troy, MI
    248-840-1056
    Journal of the Month
  • 2.  RE: Martensite in Steel
    Posted 03-09-2021 01:10
    Hi Sanjay,
    Best regards!
    Joshua Jackson
    CEO
    US Corrosion Services LLC
  • 3.  RE: Martensite in Steel
    Posted 03-09-2021 08:44
    Hi Joshua,
    Troy, MI
    248-840-1056
  • 4.  RE: Martensite in Steel
    Posted 03-09-2021 08:54
    Usualyy, for as-quenced microstructure I use "untemperd martensite" or "tetragonal martensite".
    Andrea Talamini Minotto
    Villorba Treviso
