Martensite in Steel
  • 1.  Martensite in Steel
    Posted 03-08-2021 11:14
    Troy, MI
    248-840-1056
  • 2.  RE: Martensite in Steel
    Posted 03-09-2021 01:10
    Hi Sanjay,
    Best regards!
    Joshua Jackson
    CEO
    US Corrosion Services LLC
  • 3.  RE: Martensite in Steel
    Posted 03-09-2021 08:44
    Hi Joshua,
    Troy, MI
    248-840-1056
  • 4.  RE: Martensite in Steel
    Posted 03-09-2021 08:54
    Usualyy, for as-quenced microstructure I use "untemperd martensite" or "tetragonal martensite".
    Andrea Talamini Minotto
    Villorba Treviso
  • 5.  RE: Martensite in Steel
    Posted 03-10-2021 10:00
    Thanks Andrea. I should  designate un-tempered martensite instead of martensite. Clarifies my confusion.
    Troy, MI
    248-840-1056
  • 6.  RE: Martensite in Steel
    Posted 03-09-2021 09:27
    Untempered martensite should be the right term in your report to distinguish it from tempered martensitic structure. This will provide clarity in your report, particularly for readers who may not have strong Materials/Metallurgical background.
    Nnaemeka
    Nnaemeka Ugodilinwa
    Process Engineer
    StandardAero
    Winnipeg MB
    2043187632
  • 7.  RE: Martensite in Steel
