ATTENTION "Legacy" BUEHLER POLISHER USERS / OWNERS !!!
  • 1.  ATTENTION "Legacy" BUEHLER POLISHER USERS / OWNERS !!!
    Posted 08-22-2023 13:59
    Greetings BUEHLER equipment owners, users and their associates,
    My posting herein is specifically to the attention of those who –
    Own a metallographic polishing company / Laboratory / testing facility / Head of a University Applied Material Dept.
    Lab Managers and Senior materials research engineers, Senior polishing techs with purchasing authority… WITH "legacy" BUEHLER polishing machines.
    Please forgive any "cross postings" in groups 😊
    1.       I bring to your attention the availability of the legacy piece, a "Unicorn" part, obsolete by 22 years
                  The BUEHLER Central Force drive adapter Part# 60-2499!!!
                  In June of 2021 Buehler had ONE left in the entire warehouse system. I have FOUR (4) of them…
                  It fits / is compatible with Vanguard, Vector and AutoMet Power heads. Without it, as you know, automatic / semi-automatic polishing is impossible. If you have one of these machines you need it. If you have one of these machines and this part already, MORE of THIS part will increase your workflow speed and decrease the need for "change out" on specimen holders.
    2.       I have available a legacy BUEHLER Ecomet 6 AND accompanying Automet 2 Power Head.
    Unlike the machines of this model found on equipment liquidation websites or Ebay… these two have been disassembled completely, down to the smallest washer and screw and have been fully restored.
    BUEHLER used GBC bearings in production (Chinese) which rupture and leak after time… I have replaced them all and reset with Swedish SKF bearings and changed out motor gearbox with fresh oil / lubricant, cut to length and replaced ALL internal Hosing / tubing, cleaned all electrical and connections, installed new drive belt and given them a fresh paint job.
    With the Automet 2 Power Head, I actually have the mounting pole to make the setup complete. This is the second one I have done. The first was for my own personal use…
    If this were a 1960 Jaguar E-Type this would have been a "frame-off" restoration.
    It took 10 months...
    Only Isahak Kurtjian, Senior Service Engineer at Buehler for the last 46 years could have done what I've done (some of you may know Isahak, he is the last   remaining Buehler tech employee to even HAVE experience with THIS generation of Buehler polishers).
    If Isahak could be called "Dr. BUEHLER" … then I am "Dr. FRANKEN-Buehler"!!!  It's ALIVE!!!  😊
    Mr. George Vander Voort, esteemed Senior statesman of the metallographic science and Buehler Consultant has seen the restorations and has been very complimentary.
    Available "Legacy" PARTS LISTING –
    Buehler AutoMet 2 Power Head Part #60-1950  with mounting pole
    OR Fully restored Ecomet 6  WITH the Automet 2 Power Head combination
    Buehler Specimen Holder Central Force 30mm x 4 ROUND Part # 60-3005
    Buehler Specimen Holder, Central Force 30mm x 10, Round Part # 60-5282
     VERY SPECIAL -10" mounting plate for the Buehler Ecomet 3 (VERY hard to come by without buying an entire secondary machine).
    If you have an 8 " machine... this RARE part can transform it into a 10" machine... Without having to buy another $10K-$15 machine!!! (And yes, it WILL fit on to an 8" machine).
    It requires only UN-screwing your 8" mounting plate from your Buehler Ecomet3 adapter-spindle 5/8 Shaft and   screwing down THIS plate for the transformation. THEN...you can use 10" platens and 10" papers cutting down on your work-flow time!!!
    Please feel free to write back with your interest to my personal email address  ccroth3@yahoo.com with "BUEHLER" in the subject line and I will immediately forward to you, photos of the actual part(s), restoration process and pricing (which is substantially discounted from NEW prices on Buehler's website).
    Please feel free to copy and paste this text in its entirety to any professional you may know.
    I am anticipating much interest in these legacy "unicorn" parts.
    Cordially yours, Charles
    Charles de Rothschild
    CEO Fluid Semi, LLC
    Schaumburg IL
    312-802-2692
