  • 1.  Avoiding hydrogen flaking
    Posted 02-16-2023 10:08
    What would you do to avoid hydrogen flaking related UT defects in C-Mn steels heavy wall forgings?
    Bernardo Servin
    Manufacturing Engineering Manager
    FRISA FORGE
    Laredo TX
  • 2.  RE: Avoiding hydrogen flaking
    Posted 02-17-2023 18:16
    (a) Longitudinal section                    (b) Horizontal section
    Two sections (a) cross section (b) Longitudinal Hydrogen flakes in High Manganese bigger wall thickness forgings
    High Manganese steel forgings have a tendency to pick Hydrogen and form flakes. These flakes further generate micro cracks and render the forging defective and cannot be used. The hydrogen content in the steel and picked from the process flow are responsible for this defect. Sinc the cross section is higher the processing time is higher especially during Heavy humidities in the atmosphere. Kindly share your process flow then we can check the probability of parameters causing these defects.
    SESHUPRASAD RAO
    DIRECTOR
    METEXPERT METALURGICAL CONSULTANCY PVT LTD
    Milpitas CA
    +917829721305
