FAS Membership Community
  • 1.  Digital Radiography
    Posted 06-21-2023 12:21
    Haldex is looking for a radiography facility to examine and compare Truck air brake system aluminum body valve.
    • Need to apply 125 psi system air.
    • Will compare good to bad.
    • Want to see if pistons are properly aligned or if there is any mis-alignment causing the bad valve to stick.
    • Need to do this evaluation without dis-assembly.
    Patrick Mizik
    ASM Chapter Council Chair & District 11 Rep
    Haldex SAF Holland Group
    pat.mizik@haldex.com
