FAS Membership Community
FAS Community: Share Your Expertise at IMAT 2026 - CFA deadline extended!
  • 1.  FAS Community: Share Your Expertise at IMAT 2026 - CFA deadline extended!
    Posted 03-19-2026 12:45
    The IMAT 2026 Call for Abstracts deadline has been extended to April 3, giving you extra time to share your insights with the materials community.
    Your ASM Failure Analysis Society (FAS) is leading comprehensive programming at IMAT, covering a wide range of failure analysis topics, including:
    • Aerospace & Aviation
    • Corrosion
    • Fatigue & Fracture
    • Failure Analysis Basics - Introduction to FA
    • Fractography
    • Gear, Shafts, & Bearings
    • Heat Treatment (Joint FAS and HTS Programming)
    • Litigation & Engineering Ethics
    • Metallography and Failure Analysis (Joint IMS and FAS Programming)
    • Non-Destructive Testing / Evaluation
    • Non-Metallic & Ceramics
    • Polymers & Plastics
    • Strange, Unusual, Historical and Archaeological
    • Students in Failure Analysis
    • Tools & Technique
    • Transportation
    • Welding, Joining & Brazing, & Fasteners
    This is a great opportunity to present real-world case studies, share technical expertise, and connect with fellow failure analysis professionals across industries.
    Plus, IMAT will take place in beautiful Quebec City, Canada-a perfect setting to extend your stay and explore after the conference.
    👉 Submit your abstract today and be part of the conversation!
    Jeanelle Harden
