Now through the end of May, the Journal of Thermal Spray Technology review article "High Entropy Oxides as Promising Materials for Thermal Barrier Topcoats: A Review" by Hamideh Vakilifard, Hossein Shahbazi, Andre C. Liberati, Rakesh B. Nair Saraswathy, Rogerio S. Lima, Martin D. Pugh, and Christian Moreau is free access for you to download and read!
Multi-layered thermal barrier coatings (TBCs) are deposited on gas turbine metallic components to protect them against high temperatures, oxidation, and corrosion. However, TBCs have limited working temperatures and lifetimes due to their material properties. Several approaches are tested to increase TBC topcoats' phase stability and properties.
To read the article, please visit here now through May 31st.
