  • 1.  Irregular layer at surface of Q+T steel
    Posted 06-25-2026 12:16
    I am reviewing parts that were heat treated by a new heat treat vendor. I am seeing a thin (generally less than 0.001"), irregular layer on the surface of many of the parts. The layer appears to contain porosity and oxide particles. I have attached some images showing the surface layer. I am wondering if anyone has an idea as to what could cause this? Could it be a scale layer that was partially deoxidized in the heat treat atmosphere?
    Kenneth Kirby
    Senior Project Engineer
  • 2.  RE: Irregular layer at surface of Q+T steel
    Posted 06-26-2026 09:22
    Hello Kenneth,
    Was the heat treat conducted in air with no protective atmosphere? If it was under atmosphere, check for possible air leaks inside the furnace. It could indeed be scale flakes peeling off from the contact with air (oxygen) during the heat treat.
    Best,
    George Baloi
    Chief Metallurgist
    ALD Thermal Treatment Inc.
    2656 24th Street
    Port Huron, MI 48060 USA
    Tel: (810) 357-0692   |    Fax: (810) 357-0699   |    Mobile: (810) 363-4830   |    gbaloi@aldtt.net
    ALD Thermal Treatment is a member of AMG Critical Materials N.V., Amsterdam, Netherlands
    This document contains the property of ALD Thermal Treatment. You may not possess, use, copy or disclose this document or any information in it for any purpose without express written permission. Neither receipt from any source, nor possession of this document, constitutes such permission. Possession, use, copying or disclosure by anyone without express written permission of ALD Thermal Treatment is not authorized and may result in criminal and/or civil liability.
