Hi Andre,
All testing is based on sampling, and on knowledge of the relationship of the sample and test to the performance of a real-world part. If a real-world part is tested in the identical environment to the intended service, your knowledge of the performance is 100% certain. All other tests, samples, and inspections are approximations or correlations based on inferences or past knowledge. Even a tensile test, a direct and destructive test, is of value only when a designer knows that it will be sufficient for material properties in that test direction and condition to serve adequately.
Using an inspection process gives one data but there has to be previously obtained knowledge that the test when applied, will give data that is meaningfully correlated with real-world performance. This is how codes and standards are developed.
So for example, UT at a-frequency from b-sized transducer coupled with c-coupling method scanned in d-direction using e-examination method will detect f-indication which has been shown in testing to be a significant flaw in g-service. Unless you have the knowledge tying the material characteristic and detectable indication together to the service, all of the fancy inspection specification values of a- through f- will not give much value. So you can only specify a coating test with the background of past tests that have been shown to match test results with performance. And a Pass/Fail to a NDT criterion only sorts your data, it is not meaningful unless it shows that there is value in doing the test.
I can see it! = detectable It's this size/value! = evaluated within the limits of the method It's rejectable! = a meaningful evaluation has been done compared to criteria set from knowledge and experience.
