ost-doc and master's student sought for laser-assisted cold spray at the École de technologie supérieure (ETS) in Montreal (Canada) in collaboration with the National Research Council of Canada (NRC)
  • 1.  ost-doc and master's student sought for laser-assisted cold spray at the École de technologie supérieure (ETS) in Montreal (Canada) in collaboration with the National Research Council of Canada (NRC)
    Posted 05-03-2024 12:18
    Post-doc and master's student sought for laser-assisted cold spray at the École de technologie supérieure (ETS) in Montreal (Canada) in collaboration with the National Research Council of Canada (NRC).
    TARGETED STUDY PROGRAM Postdoctoral
    ETS in collaboration with the NRC is seeking a motivated postdoctoral candidate for an innovative project focused on the application of laser-assisted cold spray deposition of aluminum alloys on aluminum extrusions. This industry collaboration project aims to make the aluminum profile extrusion process more competitive through the approach of additive manufacturing for the addition of localized reinforcements.
    The successful candidate will be affiliated with ETS and will conduct part of their work there, but the majority of the experimental work will be carried out at the NRC in Boucherville, QC, Canada. The candidate will have the opportunity to work in a dynamic and collaborative research environment, with access to state-of-the-art facilities.
    Required knowledge:
    PhD in materials, mechanical, physics or chemistry engineering, physics. or a related field
    Extensive experience in material characterization methods
    Ability to work independently and as part of a team
    Any experience in cold or thermal spraying, additive manufacturing, and laser-material interaction will be an asset.
    For more info, just click in here (speaking French is not mandatory - R&D work can be done in English): Fabrication additive de renforts sur des profilés d'aluminium par projection à froid assistée par lasers. - ÉTS (etsmtl.ca)
    TARGETED STUDY PROGRAM Master's degree
    ETS in collaboration with the NRC is seeking a motivated Master's research candidate for an innovative project focused on the application of laser-assisted cold spray deposition of aluminum alloys on aluminum extrusions.
    Required knowledge:
    Bachelor's degree in materials engineering, physics, physics engineering, mechanical engineering, chemical engineering, or a related field
    Ability to work independently and as part of a team.
    For more info, just click in here (speaking French is not mandatory - R&D work can be done in English): Application de dépôts d'alliages d'aluminium par projection à froid assistée par lasers - ÉTS (etsmtl.ca)
