PhD position open in thermal spraying: TBC R&D at Mines Paris Tech
  • 1.  PhD position open in thermal spraying: TBC R&D at Mines Paris Tech
    Posted 05-12-2023 08:34
    For those who are interested in studying the H2 fuel impact in thermal barrier coatings (TBCs), there is an opportunity for you.
    There is a PhD position open at Mines Paris Tech on this subject. The title of the thesis is: STUDYING HIGH TEMPERATURE DAMAGE TO THERMAL BARRIERS IN THE PRESENCE OF WATER VAPOR USING LASER SHOCK LASDAM METHODOLOGY
    Summary: In order to reduce the carbon impact of aeronautical engines, di-hydrogen (H2) can be considered as a fuel, replacing paraffin. However, since the combustion of H2 introduces an intense flow of water vapour (temperature and pressure), the durability of thermal barrier systems (TBC) in a very high temperature water vapour environment (T≥1200 °C) must be analysed.
    For more information, just click on this link: Propositions de sujets de these – Centre des Matériaux (psl.eu)
