Relative size of carbon and iron atoms
  • 1.  Relative size of carbon and iron atoms
    Posted 02-23-2024 11:09
    Several ASM publications (and non-ASM sources) contain information similar to the following paragraph (bold added):
    The responsiveness of steel from heat treatment is due to some important properties of iron and the metallurgical effects of carbon in iron. Fundamentally, all steels are mixtures or, more properly, alloys of iron with a small amount of carbon (along with varying amounts of other alloying elements such as manganese, chromium, nickel, and molybdenum). One important effect is the size of carbon atoms relative to that of iron atoms. The carbon atom is only 1/30 the size of the iron atom, and carbon atoms are sufficiently small to fit between the interstices of the larger iron atoms. Other atoms small enough to fit in the interstitial regions of solid iron are hydrogen, nitrogen, and boron. In general, interstitial atoms can easily diffuse-jumping from one interstitial site to another-unlike larger atoms (which can only jump by "substitution" into the vacancies within a crystal lattice). This, along with the effect of temperature on diffusion, makes the mobility of carbon responsive during solid-state heating.
    --From Introduction to Steel Heat Treatment, Steel Heat Treating Fundamentals and Processes, Vol 4A, ASM Handbook, ASM International, 2013, p 3–25, https://doi.org/10.31399/asm.hb.v04a.a0005819
    A reader recently pointed out that the statement about the relative size of carbon and iron atoms appears to be incorrect. The reader points out, "since the radius of a carbon atom is roughly 70pm and the radius of an iron atom is roughly 140pm, there is no … calculation … which would result in the size difference being a factor of 30." He pointed to the following sources concerning the relative size of atoms:
    J. C. Slater; Atomic Radii in Crystals. The Journal of Chemical Physics, 15 November 1964; Vol 41 (No. 10): p 3199–3204. https://doi.org/10.1063/1.1725697
    E. Clementi, D. L. Raimondi, W. P. Reinhardt; Atomic Screening Constants from SCF Functions. II. Atoms with 37 to 86 Electrons. The Journal of Chemical Physics. 15 August 1967; Vol 47 (No. 4): p 1300–1307. https://doi.org/10.1063/1.1712084
    From some limited investigations, it appears that the size differential may be closer to 1/8 than 1/30. We would be interested in feedback from ASM Members-how did the 1/30 comparison originate? If ASM amends the content, what would be an accurate and useful way to address the size difference between carbon and iron atoms?
  • 2.  RE: Relative size of carbon and iron atoms
    Posted 02-26-2024 08:50
    Would the volume of the atom (Radius x Radius) x Pi be what was referenced.  the difference in volumetric size is still not 1/30 but I always thought about the size difference considering volume occupied(not atomic radius)  Also heat would make a difference if we are talking about diffusion.  This does not answer the question but looking back at my notes from the 2018 Basics of Heat Treating slide deck book(from the in-class Gary Swiatek class under the dome) I see in the notes the periodic table organized by size of atoms noting carbon 6 and Iron 26.  Further in my notes I see looking at the definition of the atom a relative break down of the electron being 1/200th of a proton.
    Also the question is referencing solubility so I am wondering if temperature and crystal structure would be a consideration as the increased energy of the elevated temperature of Austenite would be the difference in volume than compared to a slow cooled pearlite structure that had the carbon diffuses out.
    Not really answered any questions but think this is a good topic to consider.
    David Lammers
    Total Component Solutions
    Sioux Center IA
    (712) 451-6646
  • 3.  RE: Relative size of carbon and iron atoms
    Posted 02-27-2024 09:59
    Thinking of atoms as hard, incompressible spheres, while sometimes useful, is fundamentally wrong. Certainly, some atoms are "bigger" than others. The quantum mechanical character of electrons means we can't really comprehend what an atom "looks like." The effects of the surrounding lattice and electron transfer will affect the size.
    Consider the size needed for an interstitial atom to move from one side to another of a close packed (FCC) plane to the other. A hard sphere would have to be about less than about 36% of the lattice atom diameter to squeeze through. Quantum mechanical tunneling would allow diffusion even of larger atoms. On the other hand, larger atoms could be accommodated in the octahedral void in an FCC crystal. (In BCC crystals, the voids are smaller but the passages between voids are larger. These explain the great differences in carbon solubility and diffusion between austenite and ferrite.)
    Perhaps the lattice expansion observed in S-phase austenite could be used to calculate relative atomic sizes
  • 4.  RE: Relative size of carbon and iron atoms
    Posted 02-27-2024 11:46
    Even though the volume of a sphere is 4/3 Pi r cubed... I think you might be on the right track with the effects of crystal structure and temperature. The solubility of carbon in iron at 1700F is much, much, greater than its solubility at room temperature. It seems to me that the size of the iron matrix's interstices is of primary interest.
  • 5.  RE: Relative size of carbon and iron atoms
    Posted 02-27-2024 12:30
    Hi,
    My data says that the radius of carbon is 77.2 Pm and that the radius of iron is 126 Pm.  Those work out to 18723 Pm^3 and 49875 pM^3, so 30:1 is not the ratio of volumes or diameters.  Just drawing 4 circles 2 inches in diameter arranged in a rectangle, the largest circle that will fit in the space inside the 4 circles is 13/16 inches in diameter.  If that model is expanded using spheres to form a cube, the size of the sphere that will fit in the interstitial position will be somewhat larger - probably in the order of 1-1/4 inches.  So 30:1 is not even in the ballpark.
    Alternatively, don't say that the ratio is 30:1 - just say that carbon is small enough to fit into the interstitial position in the cube that iron forms.
    Walt
    Walter Sperko
    Greensboro NC
    (336) 674-0600
  • 6.  RE: Relative size of carbon and iron atoms
    Posted 02-28-2024 08:01
    This is one of those facts that you read and immediately go "that's wrong". I've always dismissed it as a typographical error, perhaps even extending back to when the manuscript was typed from a written draft, as 1/3 would be a more reasonable value at the time.  It was missed and has been restated ever since.
    Kevin Jaansalu
    Technical Specialist Officer - Materials Technology | Munitions Safety Information Analysis Center | NATO HQ
  • 7.  RE: Relative size of carbon and iron atoms
    Posted 03-05-2024 15:18
    Thanks to everyone who provided responses. The general consensus is that "1/30" is wrong, but a specific ratio is difficult to calculate. Following is the adjusted wording we propose to use (the affected sentences are in bold). I am happy to receive additional feedback about this.
    The responsiveness of steel from heat treatment is due to some important properties of iron and the metallurgical effects of carbon in iron. Fundamentally, all steels are mixtures or, more properly, alloys of iron with a small amount of carbon (along with varying amounts of other alloying elements such as manganese, chromium, nickel, and molybdenum). One important factor is the relative size of carbon atoms and iron atoms. Carbon atoms are sufficiently small to fit between the interstices of the larger iron atoms. Other atoms small enough to fit in the interstitial regions of solid iron are hydrogen, nitrogen, and boron. In general, interstitial atoms can easily diffuse-jumping from one interstitial site to another-unlike larger atoms (which can only jump by "substitution" into the vacancies within a crystal lattice). This, along with the effect of temperature on diffusion, makes the mobility of carbon responsive during solid-state heating.
    Director of Content and Publishing
  • 8.  RE: Relative size of carbon and iron atoms
    Posted 03-06-2024 14:01
    Hi, Scott,
    I suggest that you follow the wording in the next sentence.
    One important factor is the relative sizes of carbon and iron atoms. Carbon atoms are small enough to fit in the interstitial regions of the larger iron atoms. Other atoms small enough to fit in the interstitial regions of solid iron atoms are hydrogen, nitrogen, and boron.
    Walt
    Walter Sperko
    Greensboro NC
    (336) 674-0600
  • 9.  RE: Relative size of carbon and iron atoms
    Posted 03-07-2024 14:06
    Here's an updated version, incorporating very helpful feedback from @Walter Sperko, @David Coulston, and @Nassos Lazaridis. I removed the bold because some minor changes were made to other sentences in the paragraph.
    The responsiveness of steel from heat treatment is due to some important properties of iron and the metallurgical effects of carbon in iron. Fundamentally, all steels are mixtures or, more properly, alloys of iron with a small amount of carbon (along with varying amounts of other alloying elements such as manganese, silicon, chromium, nickel, and molybdenum). One important factor is the relative size of carbon and iron atoms. Carbon atoms are small enough to fit into the interstitial regions of the larger iron atoms, especially in the temperature range where body-centered cubic alpha iron undergoes a phase transformation to face-centered cubic gamma iron. Other atoms small enough to fit in the interstitial regions of iron atoms are hydrogen, nitrogen, and boron. In general, interstitial atoms can easily diffuse--jumping from one interstitial site to another--unlike larger atoms (which can only jump by "substitution" into the vacancies within a crystal lattice). This, along with the effect of temperature on diffusion, makes carbon atoms very mobile during solid-state heating.
    Additional feedback is welcome. Thanks all!
  • 10.  RE: Relative size of carbon and iron atoms
    Posted 03-09-2024 13:39
    Out of curiosity, what is more meaningful about saying "interstitial regions" rather than "interstices"?
    It is also interesting that even the simplest Google search immediately yields disparate information for the radius of a carbon atom (even if in the same magnitude), shown below:
    Secondly, are hydrogen, nitrogen, and boron the only other elements (or the most common?) that can fit in the interstices/interstitial areas? If not, I assume there can only be a handful of other elements (perhaps a faulty assumption), so why not list the rest of them as well? It is a separate question of whether it is feasible for, let's say, a helium atom to sit inside an interstitial space of an iron matrix.
    Curiously, this government database of van der Waals radii lists a carbon atom radius of 170 pm vs. an iron atom radius of 194. It even lists the atomic radius of boron as 192 pm, which seems bizarre from a materials standpoint and makes it appear that boron would more easily be a substitutional element rather than an interstitial one.
    Benjamin Huebner
    US Air Force
    Macon GA
    6786415792
  • 11.  RE: Relative size of carbon and iron atoms
    Posted 03-10-2024 10:45
    If I were going to change "interstices", I'd pick "interstitial spaces".
    Anything can be an interstitial atom. Irradiated materials have many self interstitials. They're high energy and quickly diffuse to regions (like grain boundaries) where they can better be accommodated. Relative size determines the likelihood of any atom being interstitial or substitutional.
    I wouldn't get too attached to sizes that are determined for isolated atoms. We're interested here in atoms embedded in metallic crystals. How they interact with the "electron gas" that permeates the crystal is critical. If they contribute electrons (and shrink) or attract electrons (and swell) will control how they behave.
  • 12.  RE: Relative size of carbon and iron atoms
    Posted 03-13-2024 11:34
    It's been several decades but the mnemonics still work - Prof. Honegger taught us that when it comes to interstitials in iron, there's a BONCH of them.  As in B, O, N, C, H.  It may well be that the B-O was to represent only Boron.  I do not recall if there was a specific discussion of these elements' effective atomic radius within the metallic matrix but they were taught to us as non-substitutional.  In hindsight, oxygen is very reactive to be considered an atom that will migrate, but its calculated atomic radius is comparable to or even smaller than those other elements in this list.
  • 13.  RE: Relative size of carbon and iron atoms
    Posted 05-01-2024 16:56
    Hello All,
    I received the following comments from Martin Harley via email and thought I they would be of interest to those of you who are following this thread. He is not proposing any changes to the revised wording for the ASM sources that this group helped create, but he has some thoughts to add:
    I read the thread on the relative sizes of C and Fe atoms with great interest and was pleased to see the conversation was a recent one.  I have wondered on this issue many times because I often turn over in my head how I would explain certain things to non-materials engineers who I need to convince about a certain course of action.
    I came across the 1/30th thing years ago myself and have occasionally looked up atomic radii online, but never found a satisfactory explanation for why carbon is an interstitial and mobile at such a large size compared to Iron.  I agree with the posters all the way down the thread that the numbers simply don't make sense and there must be some alternative explanation for what's going on.
    I have always assumed the following and would like someone who knows more to either confirm I'm on the right track, or give me a better explanation.
    Surely iron atoms – or indeed any metallic atoms in a crystal lattice – do not spend much time physically in contact.  They are vibrating because the system still contains considerable heat.  Although we call Austenite/γ-FCC 'close-packed', remember the entire thing is at +273K + 727°C = 1000 K and it is not the atomic radius that is important, but the lattice parameter.  I imagine a grid in which each square contains one atom, but the square is slightly larger than atomic diameter since each atom spends its time bouncing off its neighbours at a frequency that would blur everything if we were small enough to see it; the atoms would appear as diffuse spheres with fuzzy edges, rather than hard-spheres like table-tennis balls.  More heat means more vibration, so at 1200°C for example, the grid squares/lattice parameter would be larger than at 1000°C, although the atomic diameter of course remains the same.  At that temperature, the gaps between adjacent carbon atoms are of such a size diffusion is easy and carbon atoms happily sit in the interstices.  Only on cooling to the 723°C eutectoid transformation does the lattice parameter shrink to the extent now too small for carbon atoms to remain in the interstices.  The lattice rejects Carbon over 0.02%, producing pearlite/Fe + Fe3C and the close packed Austenite adjusts to non-close packed Ferrite with distortion to accommodate the very small percentage of interstitial Carbon remaining.
    If the gaps between each atom is not a simple geometry problem of touching spheres, but a temperature-dependent variable, then David Lammers' reply is the closest to my proposed explanation: it's a 'volume occupied' problem, which continually changes with temperature, less so an atomic radii problem.
    Comments and feedback are welcome.
    Scott
