TWI-based PhD positions in thermal spraying available
  • 1.  TWI-based PhD positions in thermal spraying available
    Posted 01-21-2023 15:08
    The following TWI-based PhD positions in thermal spraying are available:
    Cold Spray PhD Studentship – NSIRC237A (Cambridge, UK): TWI Careers | Cold Spray PhD Studentship – NSIRC237A (ciphr-irecruit.com)
    Cold Spray PhD Studentship – NSIRC262 (Cambridge, UK): TWI Careers | Cold Spray PhD Studentship – NSIRC262 (ciphr-irecruit.com)
    NSIRC PhD - Wear-Corrosion Mapping of Thermally Sprayed Cermet Coatings for Oil and Gas Applications PhD-NSIRC-TH-22-03 (Thailand): TWI Careers | NSIRC PhD - Wear-Corrosion Mapping of Thermally Sprayed Cermet Coatings for Oil and Gas Applications (ciphr-irecruit.com)
    To know more about them, just click on the links.
