Free - Struers webinar September 8 at 2:00 PM ET
Title: Weld Bead Inspection for the Production Environment
REGISTER HERE
Speaker: @Kelsey Torboli, Applications Engineer, Struers LLC
In high-volume manufacturing, accurate and efficient analysis of welded joints is critical. Dimensional measurements are made to pass or fail parts in a production setting; these same measurements can be used to determine if a new welding process or new material produces acceptable welds for a planned application. Join Struers for this discussion on dimensional weld analysis using the StructureExpert Weld system.
In this webinar, attendees will learn about:
- Dedicated dimensional analysis software for welds, including a wide variety of measurement tools to accommodate complex weld geometry
- Qualitative monitoring of weld bead measurements over time (Example: track changes in T1 and T2 between July 2019 and January 2022)
- Powerful and detailed reporting function to generate summary reports, including customized filters (weld cell, VIN, date, shift, batch number) and custom timeframes
Biography:
Kelsey Torboli is a graduate of The Ohio State University, with a B.S. in materials science and engineering. Previously a metallurgist with the ESM Group Inc., she is currently an applications engineer with Struers LLC, and is a member of the ASM Cleveland Chapter as well as the ASM IDEA Committee. When she's not working in the lab or assisting customers, Kelsey enjoys Orangetheory Fitness and running in the Cuyahoga Valley National Park.
carrieh@asminternational.org------------------------------
