This grade is no where near new on the street, whether in the form of pipe (A335 P91), Tubes (A213 - T91), forgings (A182 - F91) or castings (A217 C12A). Originally developed at Oak Ridge National Labs as part of the fast breeder reactor program, it has become the workhorse of the power generation industry. It has replaced the 2.25Cr-1Mo (A335 P22) for boiler tubes, high temperature piping, and heat recovery steam generators. With the support of the Electric Power Research Institute (EPRI) and the ASME Boiler and Pressure Vessel Code, it has gained widespread use due to the excellent elevated temperature properties. But as the adage goes, there is no free lunch. The alloy is metallurgically complex and was unfortunately treated like the very robust Cr-Mo steels it replaced during manufacturing, fabrication, and erection. In addition, the steam side oxidation characteristics were not well understood and are a departure from other Cr-Mo steels. This has led to local hot spots and premature failures as well as down stream solid particle erosion and blockages.
Welding and heat treatment of this alloy also has to be approached with caution. There have been many dramatic failures of weldments, especially dissimilar metal welds. The fine grained heat affected zone of the Grade 91 material is the life limiting location of weldment for similar metal welds and carbon migration of a dissimilar metal weld using an 2.25Cr-1Mo filler metal can result in a much lower than anticipate creep performance.
The complexity of the Grade 91 steel weld filler metals is further exemplified by the effects of Ni and Mn on the lower critical temperatures. The AC1 can be suppressed to a point that partial solid state phase transformation to austenite is possible during post weld heat treatment resulting in untempered martensite.
The material has been in widespread use for long enough now that the material challenges are causing enough of a disturbance in the industry that it is receiving the financial funding to support further research.
The second generation alloys like A335 P92 and A213 T23 have been deployed in sufficient quantity and have been in service long enough for long term effect to start manifesting. That will likely be the heavy research area in the next 5 to 10 years.
DAVID SEGLETES
Structural Integrity Associates
York SC
(803) 487-2368
