Does anyone have experience with aging times for large 17-4 PH parts?
The heat treating guide shows a 4 hour aging times for H925-H1150 with a +45 minutes/-0 minutes note. ASMT A564/A705 also calls out a 4 hour aging time with a note of "Time refers to minimum time material is at temperature and may be varied to obtain required ductility properties." There are none of the typical "increase soak time for large section sizes" or 1 hour/inch
For large section sizes how should soak times be adjusted? For say an 8" section, starting the soak countdown when the surface temperature hits set point will result in the core being undersoaked, while the opposite will have the surface oversoaked.
I've found some sources below showing a decrease in hardness with the increased soak time, and with the print requirement often only listing hardness requirement, that can potentially be an issue if basing soak off the core temperature. I haven't found any strong information relating to corrosion or other properties, except for the ductility comment in the ASTM spec.
With many applications that we see 17-4 used for being primarily concerned with surface wear and corrosion resistance, the outer part of the section is generally the most critical. Does anyone have experience with this situation/know of any other effects from undersoaking/oversoaking 17-4?
https://ars.els-cdn.com/content/image/1-s2.0-S0254058409001424-gr5.gif from
https://www.sciencedirect.com/science/article/abs/pii/S0254058409001424Thanks,
Ryan Wilmes
Thermal Modification Technologies
Tigard OR
