For tempering temperatures there is no use neither of TTT nor of CCT diagrams, which are useful only to assess steel quenching parameters or microstructure foreseeing during quenching different dimensions pieces.
Instead, mechanical properties vs. tempering temperature diagrams for various carbon or alloy steels should be used to decide which tempering temperature is to be selected.
If diagrams of the above type lack, the article by Grange et al. on Met. Trans., Nov. 1977, can be used to calculate hardness at various tempering temperatures of steel pieces with a given composition.
Donato Firrao FASM
Torino
Sent: 06-13-2020 09:13
Subject: Tempering temperature for low plain carbon steel and low alloy steel
Hi everyone!
I'm material science engineer and work as quality engineer at heat treatment company. Besides I'm master of student at Gebze Technical University at Turkey. My department is material science and engineering.
I want to know, how can I calculate tempering temperature for plain carbon steel and low alloy steel. I know that have many parameters. Which one should I use TTT diagram or CCT diagram. I know that have many parameters.
Thank you!
Burak Turk
Material Science Engineer
trburakturk@yahoo.com
