  • 1.  Thermal Spray Simulation
    Posted 07-07-2021 12:13
    Hello all,
    I am currently researching Thermal Spray - HVOF coatings. I would like to know if there are any simulation codes or numerical equations which can be used to optimize the thermal spray coating behaviour to achieve a specific property and control the porosity as well. It will be really helpful if someone can guide me regarding the same.
    Thanks and stay safe
    Abhijeeth Nagaraj
    PhD Scholar
    Jain (Deemed to be University)
    ABHIJEETH NAGARAJ
    Jain Deemed to be University
    bangalore
    9901756678
  • 2.  RE: Thermal Spray Simulation
    Posted 07-08-2021 11:04
    Abhijeeth -
    Perhaps this is a question for the Thermal Spray community.
    Also, Google "hvof process maps".
  • 3.  RE: Thermal Spray Simulation
    Posted 07-10-2021 04:27
    Thanks a lot, James. The search keyword is really helpful. I will also communicate with the thermal spray community.
    Thanks a ton again
    ABHIJEETH NAGARAJ
    bangalore
    9901756678
  • 4.  RE: Thermal Spray Simulation
    Posted 07-13-2021 11:13
    Abhijeeth Nagaraj-
    The following is response is from John,
    who is not on this discussion board.
    "Due to the complexity of the process, optimizing process
    parameters is generally done experimentally through some
    design of experiment framework. Modeling of the combustion
    process or particle flame interactions can be done using
    commercially available CFD software (ANSYS/FLUENT, etc.)
    but aspects such as microstructure formation, coating
    properties, or the stress state of the coating tend to not
    generalize well. While the latter isn't strictly impossible
    it tends to be more of a limited academic exercise done
    through custom developed codes and I'm not aware of any
    useful commercially available software. At the end of
    the day nothing really beats the utility of a simple DOE
    with some physical intuition as the experiments tend to
    be quick and easy with direct feedback. This is especially
    true as most models rely on a significant amount of
    experimental data for parameter fitting!
    Happy to answer any questions on this. I've also linked a
    few papers below on process development for HVOF that might
    give some insights:"
    DOE:
    https://link.springer.com/article/10.1007/s11666-010-9492-1
    https://link.springer.com/content/pdf/10.1007/s11666-014-0110-5.pdf
    Modeling:
    https://www.researchgate.net/publication/350935209_A_Parametric_Simulation_Model_for_HVOF_Coating_Thickness_Control
    https://www.sciencedirect.com/science/article/pii/S147466701637642X
    Jim Quinn, Dir. of Laboratories
    Materials Sci & Chem Eng
    Stony Brook University
    Stony Brook NY 11794-2275
