  • 1.  Stellite 21 Investment Casting
    Posted 01-29-2020 10:04
    Hi All,
    I'm wondering if anyone has experience investment casting Stellite 21. I'm having issues with one part in particular--out of several other Stellite 21 castings which never have problems--an impeller the weighs approximately 20 pounds. I've seen frequent cracks in a couple different locations of the casting.
    The alloy is melted in an induction furnace under an argon blanket, poured one at a time, and cooled slowly. The parts are heat treated and then machined, which is when cracks usually become apparent. I believe the problem stems from either casting or heat treat. Does anyone have any ideas?
    Thanks!
    Adam
    Adam Miller
  • 2.  RE: Stellite 21 Investment Casting
    Posted 01-30-2020 08:46
    Hi Adam,
    Wondering who is casting Stellite 21. As you may know only Kennametal can manufacture Stellite 21 castings.
    We can help you get the real Stellite alloy components if you want.
    Matthew Yao
    Kennametal Stellite Inc.
    471 Dundas Street East, Belleville, Ontario
    Matthew.Yao@kennametal.com
    Matthew Yao
    Kennemetal Stellite Incorporated
    Belleville ON
    (613) 968-3481
  • 3.  RE: Stellite 21 Investment Casting
    Posted 01-31-2020 08:51
    Hi Matthew,
    You are correct, the alloy is not "truly" Stellite 21, but rather conforms to AMS 5385H.
    Adam Miller
    Urschel Laboratories
    Chesterton IN
    21946448114277
