  • 1.  Analysis of volatile compound without destruction
    Posted 03-04-2023 09:53
    We are observing a small streak of volatile material on PMMA part. It cannot be scraped. Any method available to analyse streak composition without destruction
    Sandur Ajith Kumar
    Consultant R&D
    TVS Motor Company Ltd
    Anekal
    +919944452591
  • 2.  RE: Analysis of volatile compound without destruction
    Posted 03-05-2023 09:06
    Hi Sandur,
    Thermal desorption GC/MS should work.  A small glass fiber matt is cleaned via heat then used to "mop" up residue.  This is then placed in the instrument for analysis. GC/MS is very sensitive so doesn't need much to make an identification.  A good chemical compound library is needed for searching unless you have a couple strong suspect. If there is a contract lab with this technique somewhat near you, they can send you heat cleaned matts in glass vials and a procedure to avoid contamination.  We use this technique a lot to solve mysteries like this.
    Best regards, Fiona
    (Assistant Professor In-Residence and Lab Director, Material Science & Engineering Dept., University of Connecticut)
    Fiona Leek
    University of Connecticut, Material Science & Engineering
    Storrs CT
    (860) 486-6937
  • 3.  RE: Analysis of volatile compound without destruction
    Posted 03-05-2023 09:55
    Dear Fiona Leek,
    Thanks for your valuable inputs
    Ajith Kumar
    Sandur Ajith Kumar
    Consultant R&D
    Anekal
    +919944452591
