  • 1.  ASSISTANCE WITH REVISION OF AMS2526
    Posted 06-23-2023 13:27
    I have been tasked to update and revise where necessary AMS2526, "Molybdenum Disulfide Coating, Thin Lubricating Film, Impingement Applied" first issued in 1979. "AMS" standards are published by the Aerospace Council's Materials Committees of SAE International.
    When my draft of the revision was circulated this Spring, there was criticism regarding the tribology testing requirements for this coating. The current requirement for "wear life" determination is "The average of specimen time to failure shall be not less than 15 minutes, determined in accordance with ASTM D2714, Procedure A.", used for "Fales block-on-ring friction and wear" testing.
    An objection to this test method was received because:
    "1) ASTM D2714-94 does not contain a "Procedure A."
    "2) ASTM D2714-94 defines a wear tester with a 10:1 mechanical load lever system for dead weight loading applied to the "bale rod". However, AMS2526 paragraph 3.3.3.1.8 defines a 30:1 mechanical load ratio. Modern versions of this test machine use pneumatic loading paired with a force transducer and digital input of load set points. The defined procedure is outdated and should be updated to specify the required normal force at the test interface, which in this case would be 30, 60, and 90 lbf.
    "3) The test does not define what constitutes a failure."
    I have no personal experience performing tribological testing and have no access to ASTM D2714 or any other ASTM documents. I am aware that selection of a tribological test method and criterion may be very dependent on the application of the part(s) being coated and tested. By the way, this is a "Periodic" test, to be performed no less than annually.
    Dave Himmelblau, Materials and Processes Specialist (Retired)
    [Dave] Himmelblau
    Mountain View CA
    (650) 968-1121
    CharlesRetired
  • 2.  RE: ASSISTANCE WITH REVISION OF AMS2526
    Posted 06-24-2023 07:40
    I have a copy of ASTM D2714. Here is the procedure and calculation/reporting information. Hopefully this helps provide some insight into the "Falex Block-On-Ring" test method:
    3. Summary of Test Method
    3.1 The test machine is operated using a steel test ring
    rotating against a steel test block, the specimen assembly being
    partially immersed in the lubricant sample. The velocity of the
    test ring is 7.9 m ⁄min 6 0.16 m ⁄min (26 ft ⁄min 6 0.52 ft ⁄min)
    which is equivalent to a spindle speed of 72 r ⁄min 6 1 r ⁄min.
    The specimens are subjected to 68 kg (150 lb) normal load
    applied by 6.8 kg (15 lb) of dead weight on the 10:1 ratio lever
    system. Test duration is 5000 cycles.
    3.2 Three determinations are made: (1) The friction force
    after a certain number of revolutions, (2) the average width of
    the wear scar on the stationary block at the end of the test, and
    (3) the weight loss for the stationary block at the end of the test.
    9. Procedure
    9.1 With the revolution counter set at zero, gently place a
    6.78 kg (15 lb) load on the bale rod, being very careful to avoid
    shock-loading. When the fluid reaches temperature of 43.3 °C
    (110 °F) start the machine and bring the speed to 72 r ⁄min.
    Record the friction force and the temperature of the liquid at
    200, 400, 600, and 4500 revolutions and check the speed at
    each of these times. Stop the machine at 5000 revolutions.
    Remove the test block and test ring and clean them thoroughly
    using solvents selected in 6.3. Remove any excess wear
    particles that have accumulated on the side of the scar by
    brushing with a camel's hair brush; weigh the test ring and test
    block to the nearest 0.1 mg and measure the width of the wear
    scar of the test block at three points: in the center and 1 mm
    away from each edge as shown in Fig. 3. Four tests are required
    to establish a satisfactory average.
    10. Calculation and Report
    10.1 Report the friction force at 200, 400, 600, and 4500
    revolutions, the weight loss for the test block and test ring, and
    the average wear scar width. Fig. 3.
    10.2 Calculate the coefficient of friction values from the
    friction force value as follows:
    f = F/W
    where:
    f = coefficient of friction,
    F = measured friction force, kg (lb), and
    W = normal load, kg (lb).
    Colin Fletcher, PE
    Sr. Advanced Materials Engineer
    Honeywell Aerospace
    Metallurgical Consultant
    Longleaf Materials Research
    Cary NC
  • 3.  RE: ASSISTANCE WITH REVISION OF AMS2526
    Posted 06-24-2023 13:14
    Charles [Dave] and co -
    You can contact Alison Fick, see below, to find out the relevant
    subcommittee members for D2714.
    Committee D02 on Petroleum Products,
    Liquid Fuels, and Lubricants
    Committee D02 Officers and Staff Support
    Staff Manager: Alyson Fick (afick@astm.org)
    Committee Officers
    Second Secretary: Barbara E. Goodrich
    First Vice-Chair: Gregory C. Miiller
    Membership Secretary: Ian P. Mylrea
    Second Vice-Chair: James J. Simnick
    Administrative Assistant: Lisa Drennen
    Editor: Mark Rosborough
    Chair: Scott Fenwick
    Subcommittee D02.L0.05 on Solid Lubricants
    D2510-22 Standard Test Method for Adhesion
    of Solid Film Lubricants
    D2511-20 Standard Test Method for Thermal
    Shock Sensitivity of Solid Film Lubricants
    D2625-20 Standard Test Method for Endurance
    (Wear) Life and Load-Carrying Capacity of
    Solid Film Lubricants (Falex Pin and Vee
    Method)
    D2649-20a Standard Test Method for Corrosion
    Characteristics of Solid Film Lubricants
    D2714-94(2019) Standard Test Method for
    Calibration and Operation of the Falex
    Block-on-Ring Friction and Wear Testing
    Machine
    D2981-94(2019) Standard Test Method for Wear
    Life of Solid Film Lubricants in Oscillating
    Motion
    D3702-94(2019) Standard Test Method for Wear
    Rate and Coefficient of Friction of Materials
    in Self-Lubricated Rubbing Contact Using a
    Thrust Washer Testing Machine
    D7217-22 Standard Test Method for Determining
    Extreme Pressure Properties of Solid Bonded
    Films Using a High-Frequency, Linear-Oscillation
    (SRV) Test Machine
    Withdrawn, Replaced 2 matching standards
    D1367-96(2001)e1 Standard Test Method for
    Lubricating Qualities of Graphites
    (Withdrawn 2006)
    D5620-94(2004) Standard Test Method for
    Evaluating Thin Film Fluid Lubricants in a
    Drain and Dry Mode Using a Pin and Vee Block
    Test Machine
    (Withdrawn 2010)
