  • 1.  Density Index of aluminium samples for hydrogen determination
    Posted 09-23-2023 06:50
    Hello, a common test used for determining the cleanliness of aluminium melt is the denstity index unit where you cool two molten Al samples, one under air and one under vacumn under a pressure of 80 mBar. Can someone explain why does the vacumn level have to be 80 mBar?
    Kruttika Kher
    Kruttika Apshankar-Kher
    Director
    Energy Systech
    Pune
    08436241631
  • 2.  RE: Density Index of aluminium samples for hydrogen determination
    Posted 09-25-2023 09:36
    Edited by Nicholas Taylor 09-25-2023 09:36
    The pressure of the vacuum will affect the result: your measurement is effectively the void volume at 80 mbar versus the void volume at ambient pressure.  If you halve your vacuum pressure to 40 mbar without accounting for it, you'll approximately double your inferred gas content.
    80 mbar is a low enough pressure for the density index test to easily discriminate gassy versus clean melts, but a high enough pressure that you can easily achieve it with a diaphragm pump and measure it with a Bourdon gauge.  You need a standard, and it's a sensible value to pick.
    Nicholas Taylor
    Research Associate
    University of Cambridge
  • 3.  RE: Density Index of aluminium samples for hydrogen determination
    Posted 09-26-2023 04:59
    Thank you Mr. Tayor for your explanation. I would also like to know whether there is any international historic agreement in which 80 mBar was agreed upon.
    Warm regards,
    Director
    Energy Systech
    Pune
    08436241631
