  • 1.  Draw Bench math
    Posted 12-14-2023 18:29
    Material Handbook 9th Editition, Volume 14
    Forming and Forging, pg 331
    Wire, Rod, and Tube Drawing
    Aproach Angle  Δ
     deformation zone  Δ ( α rad/γ)*(1+(1-γ)^.5 ) ^2
    die angle α The half angle in radians
    5 (Deg/180)*3.14156 typical 5-15 degree half angles
    D0 2.25 in
    D1 2.20 in
    α 0.0872222 B12/180*3.14
     reduction γ 1 - (A1/Ao)
    A0 3.9740625 3.14 *$B$20*$B$20/4
    A1 3.7994 3.14 *$B$21*$B$21/4
    γ 0.0439506 1-($B$18/$B$17)
     Δ 7.7627778 ( α rad/γ)*(1+(1-γ)^.5 ) ^2
    Minumum draw stress  Δmin =4.9(μ / (LN(1/(1-γ))))^.5
    coefficient of friction μ
    μ 0.11 guess
     Δmin 7.6656377
    draw stress σd
     avg flow stress σa average work per volume
    Yield Strength σy psi
    actual ys 200,000 lb/in*in
    drawing stress ratio Σ [(3.2/Δ )+0.9](α+ μ)         Another Book 5.13
    σd σy * (3.2/ Δ ) + 0.9)  (α+ μ)
    psi Draw Stress     572,776 $B$38 * (3.2/($B$24 + 0.9)) * ($B$16+ $B$33)
    Pounds Force  Stress * Area  572,776 * 3.799
    Force  2,176,205 =$B$41 * $B$19
    Draw Bench is called 100,000 pound?
    Can the Actual tested Yield be used in these calculations?
    Where do find where my math went wrong?
    David Kirchner
    COO
    High Performance Alloys, Inc
    Tipton IN
    (765) 945-8230
    xlsx
    Metal_HB_14v9.xlsx   24 KB 1 version
  • 2.  RE: Draw Bench math
    Posted 12-15-2023 07:35
    David,
    Are you really drawing a 2.25 inch diameter bar down to 2.20 inches?! That is very large material, but a very light reduction (<5% RA).
    Dave Coulston
  • 3.  RE: Draw Bench math
    Posted 12-15-2023 09:53
    The context I was writing yesterday looked good to me, but it see now it did not flow well to this formatting.
    I am looking to find out how to apply mechanical engineering math to my draw bench. While some engineers are trying to get humans to Mars, I am trying to help by cold drawing to the next level.  This data was recorded from testing done till the carriage grip broke. Now I am slowing down and checking the math.  Input was a highly cold worked stainless at 2.25" diameter and it was drawn to 2.20" diameter. This die was bought as FF RA15 6" 5° 2.200. The 5° may be the full angle, not the half angle.
    Testing results:
    2.250" diameter 212 UTS, 193Yld, 17EL, 60RA Lot G4818
    2.220" diameter estimate 200Yld
    2.150" diameter 230UTS 210Yld 14EL 54EL
    David Kirchner
    COO
    Tipton IN
    (765) 945-8230
  • 4.  RE: Draw Bench math
    Posted 12-15-2023 09:56
    Testing results:
    David Kirchner
    COO
    Tipton IN
    (765) 945-8230
  • 5.  RE: Draw Bench math
    Posted 12-15-2023 09:13
    Edited by Scott Henry 12-15-2023 09:14
    Hi,
    For those seeking additional context, these equations are found in the following article in the current ASM Handbook series:
    Wire, Rod, and Tube Drawing, Metalworking: Bulk Forming, Vol 14A, ASM Handbook, Edited By S.L. Semiatin, ASM International, 2005, p 448–458, https://doi.org/10.31399/asm.hb.v14a.a0004008
    The relevant excerpt is shown in the image.
  • 6.  RE: Draw Bench math
    Posted 12-15-2023 13:36
    David,
    I am a little bit confused by this calculation:
    I am probably not grabbing the right numbers... but when I plug values in, I get an answer that is about 1/10 of the 572,776 value you ended up with.
    Another Dave
    David Coulston
    Niles MI
  • 7.  RE: Draw Bench math
    Posted 12-15-2023 14:55
    In Excel I typed drawing stress formula as:
    σy * (3.2/( Δ  + 0.9))  (α+ μ)  = 572,776
    σy * ((3.2/ Δ ) + 0.9)  (α+ μ) = 51,760
    Draw Stress
                51,760
    $B$31 * (3.2/$B$21) + 0.9) * ($B$13+ $B$25)
    200,000 * 1.312 * .1972
    Pounds Force
     Draw Stress * Area
    51,760 * 3.799
    Draw Force
              196,657 lb
    =$B$40 * $B$17
    Thanks, you were right about the error.
    I have the updated 14A now, thanks Scott Henry.
    Can I use the actual Yield as the Average flow stress?
    David Kirchner
    COO
    Tipton IN
    (765) 945-8230
  • 8.  RE: Draw Bench math
    Posted 12-15-2023 16:58
    David,
    You ask a difficult question!
    As a ballpark number for Average Flow Stress, I would average the Yield Strengths and Tensile Strengths before and after drawing.
    Dave Coulston
