  • 1.  Furnace certification
    Posted 04-12-2023 23:42
    Looking for large box furnaces ( 600-1200 c ) certification expert ( AMS std.)  to help and assist with technical explanations and furnaces limitations for new equipment to customers.
    kfar saba
  • 2.  RE: Furnace certification
    Posted 04-13-2023 15:03
    Hello Edli. I have been in the industrial furnace business for 40 years, a specialist in combustion systems, safety, maintenance, insulation and control. I work as a remote or on-site consultant. you can find my information at www.furnacexpert.com
    [Carlos] [Carrasco]
    [Sales Director]
    [Carrasco Hornos]
    [Mexico] [Mexico DF]
    [+52 5556640951]
    [carrasco62@gmail.com][www.furnacexpert.com]
  • 3.  RE: Furnace certification
    Posted 04-17-2023 12:02
    Hello Eli,
    You will need to answer the following questions when you are specifying a box furnace:
    1. What will the furnace be used for?
    a. Heat treatment of steel in air
    b. Heat treatment off steel in controlled carbon potential
    c. Austenitizing of steel (hardening) with or without quenching capability
    d. Bright annealing or other non-carbon controlled atmospheres (brazing or stress relief)
    d. Tempering or austenitizing/tempering
    e. Materials processin
    f. Vacuum treatment or reduced pressure
    g. Others
    2. Source of Heat
    a. Natural gas or propane
    b. Electricity (resistance, plasma etc)
    3. Product Containment
    a. Can the product come in contact with products of combustion?
    b. Ceramic brick containment
    c. Metallic retort (hot)
    d. Metallic retort (cold walls)
    4. Gas Circulation required?
    5. Furnace Controls and Sensor Required
    a. Need for carbon potential sensors (dew point, oxygen sensors)
    b. Vacuum monitoring
    6. Loading and Unloading Provisions
    These are some of the important considerations.
    Ratnesh Dwivedi, Ph.D.
    RKD ENGG, LLC
