  • 1.  Oil cooling system
    Posted 03-13-2023 12:02
    Hello
    Does the spin velocity of the oil in the cooling bath influance in come way the hardness of the steel treated ?
    kfar saba
  • 2.  RE: Oil cooling system
    Posted 03-14-2023 08:07
    Eli,
    Yes, the movement/flow of the oil has a significant impact on the rate at which heat is removed from the steel, and the rate of cooling directly affects the hardness of the steel.  ASM has many resources to help you.  I have spent 15-20 years in heat treat R&D, and I can tell you that there are dozens of variables which will all come into play here (material chemistry, material shape and size, chemistry of the oil, cleanliness of the oil, temperature of the oil, flow speed, flow direction, etc.).  Let me know if you have specific questions - hopefully someone will have direct experience with your specific challenges.
    Zachary Birky
    Intellectual Property Transaction Manager
  • 3.  RE: Oil cooling system
    Posted 03-15-2023 13:06
    Thank you very much.
    kfar saba
  • 4.  RE: Oil cooling system
    Posted 03-14-2023 13:26
    Yes, the stirring rate of oil affects quenching rate and, in turn, the surface hardness and microstructure. The stirring rate affects the heat transfer coefficient between the part and oil. As one increases the stirring speed, the quenching severity increases up to a certain point and has no effect thereafter. At this point, the heat transfer becomes controlled by heat extraction through the part rather than heat dissipation into the oil.
  • 5.  RE: Oil cooling system
    Thank you !
    kfar saba
  • 6.  RE: Oil cooling system
    Best Answer
    Posted 03-14-2023 13:45
    Eli, there are two heat-treated steel characteristics that depend on the quenching process: hardness and depth of quench.
    Level of hardness depends only on the temperature of the piece in respect to the steel Mf temperature, provided that it did not undergo any phase transformation prior to reaching the Ms temperature. Then, if the piece temperature goes below Mf, it reaches maximum possible hardness (barring any residual austenite).
    Depth of quench is dictated by the rate of extraction of the heat from the component and, hence, also by the oil flow velocity around the piece.
    Donato FIRRAO FASM
    TORINO
  • 7.  RE: Oil cooling system
    Posted 03-15-2023 02:43
    Thank you !
                                     Technology Consultant
                      Aerospace Manufacture Specialist
                                       eyudkevich@gmail.com
                                  https://www.eliyudkevich.com
                                     Phone 972 (0) 52 3663911
