  • 1.  Outgas collector
    Posted 08-01-2022 03:24
    Hello,
    I have an issue with the outgas collector. We tried to work on a recovery rate of a standard solution of mixtures C8-C40 from an outgas collector, components <10 and > C27 always got lower recovery rates (0%-40%). Since we can quantify C8-C40 standards from TD-GC/MS, so I assume the issue is not from TD-GC/MS, but outgas collector chambers. We used JAI outgas collector, and the set was N2 of 200 ml/min, 200C of Mode 2 for 1 hour, Tenax TA tubes. If any suggestions, that will be helpful.
    Thank you in advance.
    Lynn
    发自我的iPad
