  • 1.  Recycled Elements Used in New Stainless Steel Production
    Posted 10-22-2024 10:55
    Stainless steel certified material test reports do not include a percentage of the pour that came from recycled elements such as iron, chrome, nickel and moly. Do most foundries just buy these on the open market, and do not know what percentage is from recycled stainless?
    John Merrill
    Principal Engineer
    EagleBurgmann
    Matthews NC
    7048407045
  • 2.  RE: Recycled Elements Used in New Stainless Steel Production
    Posted 10-23-2024 07:23
    As far as I know (European perspective, might differ from US), most stainless steel is recycled.
    It's difficult and not very efficient to produce stainless steel by the traditional blast furnace / converter route and it works much better by the EAF process that uses scrap and ferroalloys as raw material.
    So basically, if you're buying stainless steel, even if it comes directly from a producer, it's very often recycled.
    That makes the idea of following the fraction of recycled material a bit moot in my opinion.
    Veronique Vitry
    UMONS
    MONS
    +32.496.89.71.94
  • 3.  RE: Recycled Elements Used in New Stainless Steel Production
    Posted 10-24-2024 09:33
    John,
    It should have been disclosed during the audit, unless you are not asking them for scrap addition percent during the audit.
    2040 Crooks RD, Suite A
    Troy, MI 48084
    sanjay.kulkarni@msscna.com
    Cell: 248-840-1056
  • 4.  RE: Recycled Elements Used in New Stainless Steel Production
    Posted 10-23-2024 08:05
    Edited by Daniel Baker 10-23-2024 09:13
    John,
    There are no single best practices around melt makeup that every foundry follows.  There are a number of different factors that will go into the melt makeup.  The biggest of these is scrap availability near the foundry.  If there is plentiful scrap of similar chemistry makeup to the needed cast grade, I would expect the recycled content to be high.  If the scrap is not readily available, the recycled content would be much lower.  A chemistry/mechanical property certification generally will not include melt makeup.  If recycled content is required, that would need to be negotiated at time of order and would likely be a separate document listing generic recycled content and not specific to each heat.
    Thanks
    Daniel Baker
    Senior Metallurgist
    LIFT
  • 5.  RE: Recycled Elements Used in New Stainless Steel Production
    Posted 10-24-2024 10:14
    The amount of recycled material would vary from heat to heat, depending on availability of scrap of that particular grade etc.  Worldwide the amount of recycled material used in making stainless is about 60%, but is much higher in the U.S. and Europe.  Individual producers can give you an average for their production.  As the demand for stainless is increasing every year, and it has a very long life in most applications, the availability of stainless scrap is limited.  It is estimated that 95% of all stainless steel is recycled at end-of-life.  Since insufficient stainless scrap is available, producers will use carbon steel scrap for a portion of the heat and add new chromium, nickel and other alloying elements as needed.  Search using recycle at www.ssina.com and at www.worldstainless.org for more information.
    Gary Coates
    Manager, Technical
    Nickel Institute
    Mississauga ON
  • 6.  RE: Recycled Elements Used in New Stainless Steel Production
    Posted 10-25-2024 10:00
    At Cummins, nearly all of our steel, stainless or alloy, is majority made from recycled scrap.
    Steven Ferdon
    Director Engineering Technology
    Cummins Engine Components
    Columbus IN
    (812) 344-0276
  • 7.  RE: Recycled Elements Used in New Stainless Steel Production
    Posted 10-26-2024 11:57
    I daresay that nearly all alloy systems now regularly incorporate significant percentages of recycled content, exceptions being some tramp elements (eg, cathodic phase formers like Fe, Ni etc in critical Mg and Al alloys). These can degrade corrosion and fatigue performance.
    James Cotton
    Technical Fellow, Retired
    N/a,Consultant
    Issaquah WA
    (425) 223-8060
