  • 1.  Soo Line Engine 1003: A Brief History and Failure Analysis of Wrought Iron Boiler Stay‐Bolts
    Posted 02-08-2023 08:49
    Edited by David Guisbert 02-08-2023 08:53
    The Notre Dame Chapter would like to invite everyone to this exceptional virtual presentation:
    Speaker: Dr. Josh Mueller
    Date: Monday, February 20, 2023
    Time: Login 6:45 PM, Presentation 7:00 PM
    Duration: Approximately one hour; questions and answers to follow
    Registration: Please contact Dave Guisbert at deguisbert@aol.com by February 20, 2023.
    Meeting login information will be sent to all who register.
    Abstract:
    Engine 1003 is a steam locomotive that was operated by the Minneapolis, St. Paul, and Sault Saint Marie Railroad (known as the Soo Line), which had a railroad network that extended across the upperMidwest. Manufactured by American Locomotive (ALCO) in 1913, Engine 1003 was officially retired from the railroad in 1959. In the mid 1990's, 1003 was partially restored in accordance with Federal Railway Administration (FRA), allowing it to operate on the nation's railroad system again. In 2011, as part of an FRA 1472 inspection, it was noted that some of the telltale staybolts around the boiler were expelling small quantities of water when the boiler was under pressure; this is an intentional function of the telltale feature of the bolt to indicate if the staybolt has been internally compromised. Upon disassembly of the boiler, it was observed that the telltale staybolts that indicated failure were not fractured or corroded in a manner that would enable egress of boiler water through the telltale hole; the staybolts were heavily corroded but did not visually appear to be compromised upon inspection. Recently, an analysis of the original wrought iron staybolts from the 1003 has provided additional context on how these aged bolts may have indicated failure during operation while appearing functionally sound upon later inspection. The present talk delves into a brief history of the Soo Line and Engine 1003, as well as the technology for producing wrought iron at the turn of the 20th century. Microstructural characterization from optical and scanning electron microscopy with energy dispersive Xray spectroscopy of a staybolt from Engine 1003 showcase the wrought iron microstructure of the bolts and support a proposed failure mechanism of telltale staybolts.
    About the speaker and authors:
    Josh
    Mueller, PhD
    Josh Mueller is a Research and Development Engineer in the Dynamic Structure Design and Engineering Group
    at Los Alamos National Laboratory (LANL) where he serves as the metallurgical technical lead and focusses on
    materials for impulsively loaded pressure vessels. He also maintains a Research Assistant Professorship role
    within the Materials Science and Engineering Department at Michigan Technological University. He earned a
    Ph.D. from Colorado School of Mines in Metallurgical and Materials Engineering, and a B.S. in Materials Science
    and Engineering from the University of WisconsinMadison. Before working at LANL, he gained industry
    experience from working at various manufacturing companies where he conducted research & development and
    failure analyses. His primary research interests include phase transformations and microstructural evolution
    associated with multiphase microstructures, as well as microstructuremechanical property relationships of metals
    and alloys. He is particularly interested in microstructural design to enhance yield strengthtoughness
    performance and incorporating thermodynamic and phase field simulation for an integrated computational materials
    engineering (ICME) approach to alloy and heat treatment development.
    Virginia
    (Ginny) Euser, PhD
    Ginny Euser is a staff scientist at Los Alamos National Laboratory (LANL). She earned her BS (2014), MS (2017),
    and PhD (2020) from the Colorado School of Mines in Metallurgical and Materials Engineering. Her graduate research
    focused on exploring novel, rapid thermal processing routes to improve the strengthtoughness performance of
    mediumcarbon, highstrength steels.  Ginny joined LANL in February 2020 as a postdoc, where she investigated the
    link between microstructure and the dynamic properties of metallic systems.  She converted to a staff scientist position
    in October 2022 and is now involved in investigating material corrosion and embrittlement phenomena.
    Her overarching technical interest lies in linking the processing, microstructure, and properties of metallic systems.
    Matthew
    Harvey
    Matthew Harvey started his metal working training in an ornamental iron shop while still in high school. Later, he
    earned a technical diploma in Machine Tooling from Moraine Park Technical College. He completed an
    apprenticeship in tool and die, before becoming a shop foreman where, for over 15 years, he specialized in deepdrawn
    metal stamping. In 2015, he opened his own business which provides machining and welding services.
    Currently, he is the only individual Rstamp certificate holder in the state of Wisconsin, enabling him to make
    repairs and alterations to pressurecontaining components that conform to the American Society of Mechanical
    Engineers (ASME) Boiler & Pressure Vessel Code (BPVC), including restoration and repair of steam engines.
    Matthew currently serves as president of the Wisconsin Historic Steam Engine Association (WHSEA) and vice president of
    the Steam Locomotive Heritage Association (SLHA), the operating entity of the restored Soo Line Engine 1003. His
    interests include tools, metal forming, forging, tool steel, tool welding, and steam engines.
    David Guisbert
    Associate
    Quality Associates Metallurgical Services
    Niles MI
    (574) 485-9359
    pdf
    ASM_ND_Meeting_2023-02.pdf   345 KB 1 version
  • 2.  RE: Soo Line Engine 1003: A Brief History and Failure Analysis of Wrought Iron Boiler Stay‐Bolts
    Posted 02-17-2023 12:13
    Dear David,
    This Monday 20 presentation seems to be very interesting!!
    So excited to listen to Josh Mueller!! who is part of the Archaeometallurgy Technical Committee!!
    Good Luck!!
    [Patricia Silvana] [Carrizo]
    [Ms.]
    [Chemical Engineer]
    [Mendoza] [Argentina]
    [+542615577229]
  • 3.  RE: Soo Line Engine 1003: A Brief History and Failure Analysis of Wrought Iron Boiler Stay‐Bolts
    Posted 02-18-2023 09:17
    As a graduate of Michigan Tech, I have a certain fondness for all things U.P.. I look forward to this presentation!!
    David Coulston
    Niles MI
