  • 1.  staining/discoloration of aluminum ingots
    Posted 06-16-2022 13:25
    We produce alloyed aluminum ingots for foundries to re-melt and make functional castings.  To make the ingot shape the molten metal comes out of the furnace tap hole into the mechanism that distributes it to each ingot mold as they come by on a continuous conveyor.  The mold conveyor takes the filled ingot molds to a water spray area to quickly cool down the molten metal and to solidify the ingots.
    Some times the ingots get a stain or discoloration instead of the usual bright shiny silver color.  The color is usually a dull yellow to brown.  Sometimes an iridescent pink/blue, like oil on water.  This colorizing has been described as an oxide layer just a few atoms thick that reflects the light like a diffraction grating, thus the colors.  This is harmless and usually goes away upon re-melting at our customer's foundry.  However, some customers don't like this.  They question the quality of the ingots.
    Is there some way we can prevent this from happening, or stop it once we see it starting to discolor our ingots?
    Ron Zakrzewski, Laboratory Manager
    Custom Alloy Sales
    Ron Zakrzewski
    Laboratory Manager
    Custom Alloy Sales
    CITY OF INDUSTRY CA
    16263693641
  • 2.  RE: staining/discoloration of aluminum ingots
    Posted 06-17-2022 09:00
    You can scarf the billet  with Al shot media just enough to get dull finish off the surface. Doesn't have to be high hardness.
    Troy, MI
    248-840-1056
  • 3.  RE: staining/discoloration of aluminum ingots
    Posted 06-17-2022 11:21
    Thank you, Sanjay.  But that's simply not practical.  I forgot to mention that we're a pretty big operation.  If we had one heat (batch) go off color, that would be 3000 ingots.
    As to the cause, I'm placing my bet on the cooling water hardness and/or pH.
    Ron
    Ron Zakrzewski
    Laboratory Manager
    Custom Alloy Sales Inc.
    Contact: (626) 369-3641 ext. 2800
    Email:   Ron.Zakrzewski@customalloysales.com
    https://customalloysales.com
    All price quotes are subject to confirmation
    The information in this e-mail and any attachments is confidential and may be subject to legal professional privilege. It is intended solely for the attention and use of the named addressee(s). If you are not the intended recipient, or person responsible for delivering this information to the intended recipient, please notify the sender immediately. Unless you are the intended recipient or his/her representative you are not authorized to, and must not, read, copy, distribute, use or retain this message or any part of it
  • 4.  RE: staining/discoloration of aluminum ingots
    Posted 06-18-2022 03:02
    You hunch is right, the discoloration is primarily due to some minerals present in the water. The normal way to get rid of this problem is to have a slightly acidic water if that is possible for you. Also corrosion inhibitors are available in the market that make the cooling water acidic and probably won't have any environmental impact. Since it is not always happening, you may check the water on days that does happen.
    Vivek Singal
    Mumbai
    919769208775
