Tim Foecke in NYTimes article
  • 1.  Tim Foecke in NYTimes article
    Posted 07-15-2023 16:01
    Folks -
    Time Foecke is in a NYTimes article:
    "Tim Foecke, a retired forensic metallurgist who has
    done mechanical testing and failure analysis on metals
    and carbon fiber, said the change in hull geometry
    from a tight sphere to a lengthy tube may have contributed
    to Titan's catastrophic failure. A larger hull needs to be
    stronger and thicker to withstand the same pressure as a
    smaller one. In two hulls of the same thickness, he said,
    the larger one would "collapse or buckle" first."
